What about Black Silverado/Sierra Photos?
It has ReadyLift 3" rear blocks and ReadyLift shock extensions. Rake is no greater than factory before BDS 2" leveling kit, ZoneOffroad 1.5" body lift, and ReadyLift blocks. My camera angle was off making rake exaggerated. IIRC, the rake is now not quite 2". It still retains the factory 20" rims/tires at this time.
So 2" front 3" rear and 1.5 body. That would explain it. Probably the stock wheels and tires exaggerates the look as well.
I've done the 2" front and am debating a 2" rear block and the 1.5 body lift. Did you do the body lift yourself? If so, how tough was it?
I had a shop install the body lift. It took them about 7hrs. I considered going with the 2" block but I had read the factory blocks are 1.25" so I was worried it would be perfectly level and then when I put something in bed or pull, my nose would be up in the air.
With just a 2" in the front my rear is .75" higher. Figured with the 2" rear block it'd sit 1.5" higher. I don't tow anything so not a big deal for me. The directions for the body lift don't look all that tough, just time consuming. Kills me to pay a shop $600-$800 to install a $169 kit!
looks good . why not have the running boards line-x , it will hold up better.
A can of plastidip cost $5.67 at the home depot. I would rip them off but the wife uses them. Praying one day she will buy me some amps!
Sent from my SAMSUNG-SM-G890A using Tapatalk
What tires are you running? Size looks nice!
275/65 r20 Nitto terra grapplers g2s
You running spacers? The pictures look like they stick out more.
No spacers just stock wheel. Viewing from the front or back, they are tucked under the fender
    247.7k
    2.6m
    Fezic
    Fezic
  • Who's Online   2 Members, 0 Anonymous, 614 Guests (See full list)
