new tires need a level kit
im getting 18x9 fuel rims with LT285/65R18 trail grapplers on my 04 silverado would it look better or be better with a level kit it looks level now but just making sure. Im not trying to get a lift kit thopost-136092-0-28477200-1417490084_thumb.png
If your truck is level, then a leveling kit isn't going to do anything but raise your front end and make your ride harsh. It could also screw up your CV and ball joint angles.
I want to put leveling kit on my 2014 4x4 buddy at chevy dealer says don't go over 2" on level kit for front end they are finding when they go to 2 1/2" level control arm hits underneath on the truck.
my 07 and 11 silverdo with the wind dam up on front bumper was a soft plastic/rubber that would bend if you went through a low spot, the 2014 wind dam is a much harder plastic, went through a dip very slowly a week ago and the right side hit the rocky area I was driving through and it tore it at the connecting pins/bolts on that right said sooooooooooo it has been removed till this spring when it heats up and it is needed to direct air for cooling and I get a level kit on the truck.
