Difference K2500-K3500 SRW
Question for you folks(experts).  What is different in the drive train between a 2500HD 4X4 and the 3500 4X4 when both have Identical engines/transmissions/axle ratios and single rear wheels?  I don't think the frame is any different, so what's the difference?  Aside from price.  I'd really like to know. ???
I don't think you can buy a 3500 single rear wheel...  because it is actually called a 2500HD.  The GVW of the 2500HD is 9200 lbs. or the equivalent of a 3500 series SRW.
I believe the GM line-up to be...
2500 = 8600 GVW
2500HD = 9200 GVW
3500 = 11400 GVW (but it is a dually)
I was under the impression that all 3500 series trucks were duallies.  (please correct me if I'm wrong)
I also thought that all 3500s were dual rear wheels since the change in the 2001 model year ??
Only 1 ton truck that you can get single rear wheels with is the F-350 i believe
Yes.. that is correct.. just checked the manual.... 2500HD is SRW version of "1 Ton" and 3500 is dual rear wheel.
I would say that 1/2; 3/4; and 1 ton are kind of misnomers.... I think the payload of a 3500 w/ dual rear wheels is around 5,000 lbs (2.5 tons) and the payload of the 2500HD is 3100 lbs (1.5 tons).  Obviously, in most cases, the payload goes up as you get into the 250 / 2500 and especially in the 350 / 3500 range but I'm not sure a SRW F-350 would have a payload capacity of the Silverado 3500 w/ dual wheelseven both are referred to as "1 Ton" trucks.  It would be interesting to compare the 2500HD SRW w/ the F-350 SRW and the 3500 with the F-350 dullie.... anyone have these numbers handy?
It also depends upon what year you are talking about.  The axles can and do differ between the 2500HD and 3500 even if the ratio is the same.  3.73 is available on 2500HD, 4.10 is standard on 3500.  The lightest GVW 2500HD with gas engine may still have a partial floating axle (they did in 2000, not sure about now).  Spring rates and ride heights vary.
GVW Range/Payload: 2500HD: 8600 - 9220 / 3076 - 3760
                            3500:  11400 - 12000 / 4941 - 6200
Bob....do you have the figure for max trailer weight for a K2500 (light duty) 6.0 with 4.10's?  We were just discussing this on the 1500 forum.
I was unaware that GM had discontinued the 3500 SRW.  Sorry for the confusion guys.  I was wondering why everyone was referring to the 2500HD as the 1 ton.  My 2500HD 4X4 has the 4.10 ratio and if i'm not mistaken the axle is a full float and Identical, other than the dually ends, to the K3500 for '03?(not talking springs).  I never saw many 1 ton SRW trucks out there before they stopped making them, but I sure see alot of 2500HDs now.  I suppose the prices on the 1500 4X4s have gotten right up there with the 2500HD so why not go heavier and higher.
The towing capacities for the K2500 (non HD) with 4.10 's are:
Ball Hitch:  10,300 lbs
Fifth Wheel: 10,300 lbs
Note: these are for the K2500 (4x4) model that is only available in an excab shortbed configuration.
Dodge offers their 3500 in a SRW.  It comes standard as a DRW, but has an option to remove the dual wheels and lowers the price about $870 if I remember right.  I don't know what that does to the GVW though.
Initial question dealt with the C/K series which was discontinued in 2000.   In the C/K series 1988 - 2000 the GVWs were as below:
1500 - 6200-6600 GVW
2500 (6 lug wheels) 7700 GVW
2500 (heavy duty, 8 lug wheels) 8600 GVW
3500 (Single rear wheel) 9200 GVW
3500 (Dual rear wheel) 10,000 GVW
3500 (cab and chassis) 12,000 GVW
3500HD (cab and Chassis) 15,000 GVW
All this changed with the introduction of the silvarado series and the silvarado heavy duty trucks.  See earlier post for their ratings.
