2014/15+ HD PowerFold OEM Tow Mirrors (The Ones We've Been Waiting
superchargedss
  • Replies 1.4k
Which ones? pictures? if they are the new model tow mirrors that power fold with all the bells and whistles that come with it, then I will buy them. let me know!
Edit: I should add that I have cash in hand.
They GM part number is #23465677.
The model K2XX DFG/SIG
I'm not sure if they are power folding but they are all black.
If your still interested I can text you pics. My phone and forums don't like each other.
Sean , 7135178072
My question that everyone seems to dance around is regarding the amber lights.....
I understand from the first post that the solid orange wire can be moved and connected to the red/blue wire to have it on with the blinker.
The million dollar question is how do you achieve the amber light to work as the blinker AND work as a running light when the headlights are on?
What additional wire do you tie into to achieve the running/clearance light capability?
Or will leaving the orange wire alone and simply adding a wire tap to the red/blue wire allow for both functions to work properly?
I found out if you have a truck with the AVF RPO the ip harness is wired for the DQS mirror. so I added a pin to the door connector and was able to get the LED's to work as designed. Thanks for the response.[/quote
Do you have the pin numbers for the door harness?
