Can we get a regular cab thread going? Stock, lifted, lowered?
10 minutes ago, Nasty said:
Hoping he wants to upgrqde his cluster because i have an hmi and cluster for sale :)
I wish that would work in my truck and get the steering wheel controls to work but nobody can tell me for sure since I had that weird iob radio. :sigh:
It wood as long as you have i0s4or higher and i have an ios 5 hmi im pulling put of my truck soon.  @harltech did it with a wt
I had the oddball iob 7" radio so nothing is easy to upgrade
18 minutes ago, ayyo_alcatraz said:
I just signed up on this page still getting use to it, but when I figure that out i will but i have a instagram page where ive done most of my mods@ayyo_alcatraz
Followed!
5 minutes ago, Nasty said:
I might have a hookup on an 8" screen for you
I'm just gonna keep the Alpine and add the Mosconi. (my wiring is different so irs not a simple swap and steering wheel controls still won't work)
The I0B does NOT use a separate HMI module like the The I04-6.  it has a single Radio module that does everything.
That being said,  steering wheel controls actually go through the IPC, so maybe if you upgrade the IPC to an uplevel style they might work.
Thanks qwank! I knew it didn't have the hmi but I don't know what the IPC is(?).
Just now, Nasty said:
So marv can use my old cluster? :)
Possibly, I think someone on here did swap the base cluster for the style that is like your old one. I'm not sure what was involved since I didn't read the thread and it's not something we would do at the dealer.
  It's worth a try since I think you guys are close to each other and could probably play around with it.
Illsend you the cluster. Plug it in. See what happens.
10 minutes ago, qwank said:
Instrument Panel Cluster
Doh and thanks!
Sounds good!
