Mike1220 Posted September 10, 2014 Share Posted September 10, 2014 I have a question regarding a modification I would like to do on my truck that goes along with this mod. I've been wanting for my cargo lights/ bed LEDs to turn on when you use the fob to unlock the doors. Has anybody tried this or perhaps know how to accomplish this? http://www.gm-trucks.com/forums/index.php?/topic/164156-Cargo-Lights-on-with-Reverse-Lights Sent from my iPad using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
clatla Posted September 11, 2014 Share Posted September 11, 2014 I have some diodes that were payed forward so now its my turn. Shoot me a PM. Sorry they are all gone. Quote Link to comment Share on other sites More sharing options...
pkpouttu Posted September 19, 2014 Share Posted September 19, 2014 Just did mine. Literally took a couple minutes. Ran mine from the 22 to 10 and love it. Wish it came from the factory with this opition. In that spirit I have 3 to send out as clatla sent me extras. If you hurry I can get them out today as the mail guy didn't come yet. PM me your address please. Quote Link to comment Share on other sites More sharing options...
1057 Posted September 20, 2014 Share Posted September 20, 2014 (edited) Just bought a 5pk of IN4004 off eBay. When they come in I'll only need one. With that said I'll have 4 I'll pay forward. If anyone wants one of the 4 remaining send me a PM with your shipping info and I'll get one out to you. Edited September 20, 2014 by 1057 Quote Link to comment Share on other sites More sharing options...
BigBadSierra Posted September 21, 2014 Share Posted September 21, 2014 Bought a pack of diodes from the source. Did the mod today jumped off the parking lights relay. Works like a charm. Quote Link to comment Share on other sites More sharing options...
SouthernSilveradoGuy85 Posted September 28, 2014 Share Posted September 28, 2014 Maybe I missed it while looking through the comments, but would it also work with a short jumper wire or is a diode safer? Quote Link to comment Share on other sites More sharing options...
CoasterCOG Posted September 28, 2014 Share Posted September 28, 2014 Maybe I missed it while looking through the comments, but would it also work with a short jumper wire or is a diode safer? You need the diode to prevent current from flowing back and turning on the high beams when you activate the fogs. 1 Quote Link to comment Share on other sites More sharing options...
Spurshot Posted September 28, 2014 Author Share Posted September 28, 2014 (edited) You need the diode to prevent current from flowing back and turning on the high beams when you activate the fogs. The diode is acting like a one way valve for current. Steve, just find a Radio Shack or any electronics store and get a diode. There are many diodes that will work, as have been verified by the guys that used them on this thread. They cost literally pennies. Edited September 28, 2014 by spurshot Quote Link to comment Share on other sites More sharing options...
SouthernSilveradoGuy85 Posted September 28, 2014 Share Posted September 28, 2014 You need the diode to prevent current from flowing back and turning on the high beams when you activate the fogs. Thanks, makes sense. The diode is acting like a one way valve for current. Steve, just find a Radio Shack or any electronics store and get a diode. There are many diodes that will work, as have been verified by the guys that used them on this thread. They cost literally pennies. Only reason I asked was because I have a short piece of wire from when I programmed a new key fob for my old 98. Plus I was just curious. Wasn't wanting to save money since diodes are very cheap. Quote Link to comment Share on other sites More sharing options...
Tlarose Posted September 28, 2014 Share Posted September 28, 2014 Just to confirm, the high beams will flash on then off when you active the fogs while in low beam? Ps check valve (one way valve) Quote Link to comment Share on other sites More sharing options...
Spurshot Posted September 28, 2014 Author Share Posted September 28, 2014 Just to confirm, the high beams will flash on then off when you active the fogs while in low beam? ... I hadn't noticed that...maybe. My setup is the 10-18 jump. Fogs are controlled on-off in the normal way by the button on the headlight control, when either with the low beams on or in daylight with only the DRLs on. If the high beams on commanded, the fogs will turn on, if they were off, then return to off when commanding low beam. If the fogs were on when the high beams were commanded, they will remain on for the high beams and stay on when going back to low beams. I use this configuration because I can tie in a relay to the fogs to run a set of wide driving lights and not have to run a switch to fuss with when I need to shut them down for oncoming traffic. I don't have to run wires thru the firewall either. Very convenient setup. Quote Link to comment Share on other sites More sharing options...
Tlarose Posted September 28, 2014 Share Posted September 28, 2014 I hadn't noticed that...maybe. My setup is the 10-18 jump. Fogs are controlled on-off in the normal way by the button on the headlight control, when either with the low beams on or in daylight with only the DRLs on. If the high beams on commanded, the fogs will turn on, if they were off, then return to off when commanding low beam. If the fogs were on when the high beams were commanded, they will remain on for the high beams and stay on when going back to low beams. I use this configuration because I can tie in a relay to the fogs to run a set of wide driving lights and not have to run a switch to fuss with when I need to shut them down for oncoming traffic. I don't have to run wires thru the firewall either. Very convenient setup. Perfect, thank you for the quickly reply. I'm gonna order some diodes right meow Quote Link to comment Share on other sites More sharing options...
Amiodynski Posted September 28, 2014 Share Posted September 28, 2014 I'll be more than happy to pass some along too. Sent from the future using a Fax Quote Link to comment Share on other sites More sharing options...
pkpouttu Posted October 5, 2014 Share Posted October 5, 2014 Added some Cree LED foglights to the truck yesterday. BTW I still have some diodes left to send out. Quote Link to comment Share on other sites More sharing options...
Spurshot Posted October 6, 2014 Author Share Posted October 6, 2014 Question for someone with a GMC that hasn't done this mod yet: Can you turn on your fog lights in the daytime without turning on your headlights? My foglights will work in the daytime but not turn on the headlights. I have the 10-18 mod. Quote Link to comment Share on other sites More sharing options...
