Daryl Z71's 2006 Silverado Z71 Re-build
Daryl Z71
Well the frame is painted, and one bushing installed. Going to install the 2nd one tomorrow, and try one last time to get the torsion keys separated from the bars. I sprayed them all day with PB blaster, and the one key moved some, but the other one won't budge. It's just ridiculous. Looks like I'll be taking a torch to them tomorrow to heat them up.
I coated my bars with a little anti-sieze too in case I ever had to remove the keys again for some reason.
Make sure you wire brush that bar so it's a little easier to slide the new key on, take a grinder to the rust if need be
Both of you guys read my mind.
I believe first time I did my bars, before I replaced them, I used anti seize as well. Also, lay your bars on a flat surface make sure they aren't torqued, mine were, making me lose lift
Oh I'm going to load that SOB up with anti-seize. The bar I got out looks almost straight as an arrow. So far so good.
Here are some fender measurements.
Front before:
Front after:
Rear after:
The before image of the front is a little misleading. It's actually over 35" so I'm estimating that I got around 2 1/4" of front lift. After I add my rear block I may raise the front more depending on where it sits after that.
After looking at the torsion bars they were torqued a small amount, but it doesn't seem to affect the lift too much. The keys were 1-3" lift so I imagine that helps. As far as ride goes it doesn't seem to ride any worse to me.
Don't raise the front anymore, just added stress on your tie rods and ball joints
That was my thought too. I'll have to get a picture of the angles tomorrow. They're not as bad as I thought they would be, but I could use others thoughts as well. It was about a half inch higher, but I lowered it down for the reason you said. Maybe I'll just add the Hellwig helper spring like you did, and not install the rear blocks...
I didn't want to go any higher in the rear considering I didn't want to have to use a drop hitch
