Daryl Z71's 2006 Silverado Z71 Re-build
Daryl Z71
So I went today and got what I was looking for out of my buddies truck. Installed it when I got home. I'm unsure of what to do about the empty hole though. I have the airbag lock/unlock piece I could put in the open spot, but I think it will be out of place...
thats where my airbag switch is. will the blank fit on both sides? If it does im thinking of relocating my switch out of sight and putting in the pocket. If it will fit i'll mail you the blank piece to put there off my truck. try the long piece on the lower side too if either fits i'll send them
Edited by cjb321
Won't fit sadly. I tried flipping it so it would fit, but it either sticks out too far or sticks in too far. I'm going to try tinkering with it again tomorrow.
did you try the long piece on the low side too? you quoted me before i edited
I thought of that, but the long piece is connected to the frame of the whole piece that clips into the dash.
ok you got me curious so went out and tore my dash apart, here is what i found:
i had to cut the little tab closer to the black faceplate off the switch to make it work.
the blank panel i just turned upside down also
Edited by cjb321
So apparently the blank will fit in either side?
only the switch not the blank panel
wondering if there is a difference between the 99 and 06. i can send the whole setup to you if i can find a pocket to put in mine
I see. No idea on that one. Whatever you want to do man it's your call. All this figuring to keep a stock look lol!
    247.7k
    2.6m
    Jason Coe
    Jason Coe
  • Who's Online   4 Members, 0 Anonymous, 913 Guests (See full list)
