Daryl Z71's 2006 Silverado Z71 Re-build
Daryl Z71
I believe that's an ambient air temp sensor... I guess unplug it and see what happens to the temp readout.
Unplugged the black one and nothing changed. Unplugged the gray one and the temperature didn't display anymore.
Didn't have time to fix it today, but I think I found my issue.
When I went to pull out the loom under the truck it was stuck between the trans line and radiator in one spot. Once I saw that I figured that the wire rubbed through or broke there. Pulled it out and sure enough it's almost broken in half.
That is the dirty side. And every one i have seen has it there.
+1 I just did my valve cover gaskets and the drivers side was by far the nastiest. Plus there's way more space on that side.
Sent from my SM-G360V using Tapatalk
Fixed the headlight wiring, and wrapped the wires in new loom and tape. Also installed a new Denso upstream 02 sensor, and i have a Denso downstream sensor on the way. The engine light went off, and hasn't come back yet. Truck is running great now and pulled down great MPG on my trip today.
  • Like 3
Finished installing the rest of the new Denso oxygen sensors this weekend along with a new Delphi mass airflow sensor. Truck runs a lot smoother now, and gets good mpg. On another note I had another goodie show up today.
  • 1 month later...
What led you to suspect the o2 sensors were bad? I've tried every last thing I know of to get rid of my rough idle and random misfire. Going to try those sensors next and hope like hell that finally fixes it.
Sent from my XT1080 using Tapatalk
I got an engine light telling me they were bad so I just went ahead and replaced all of them along with a MAF. I figured since I was planning on a tune eventually it'd be best to have all those things working correctly anyhow. Edited by Daryl Z71
  • 4 weeks later...
So I haven't done anything to the truck for a while, but that's about to change. I ordered a set of Weathertech floor liners for the front along with two rolls of sound deadener. My carpet has a big hole in it and smells so I'm going to rip it all out, and put sound deadener on the floor, and up the back of the cab, and then replace the carpet with new. My extended cab doors also won't unlatch at the bottom so I'm going to fix that while I'm at it. Stay tuned...
My drivers side extended cab door doesn't unlatch very well either. I haven't messed with it yet, so I don't know what's causing it to hang up.
This gave me an idea of what it could be.
http://www.silveradosierra.com/interior/extended-cab-door-stuck-bottom-wont-release-t5269.html
    247.7k
    2.6m
    Jason Coe
    Jason Coe
  • Who's Online   2 Members, 0 Anonymous, 861 Guests (See full list)
