Daryl Z71's 2006 Silverado Z71 Re-build
Daryl Z71
  • 3 weeks later...
I had the right post cat go out, and currently have the left pre cat throwing a "heater" code. The right one has been fine since I replaced it, just need to order and do the left.
Does it only throw the code when it's a cold start?
It threw them today when I came out of the Yamaha dealer after letting it set for about a half hour.
I would check the fuses first. O2A/02B I think... If fuses are good I'd check and make sure they're getting power (key on, motor cold).
Okay I'll look at that tomorrow. I've had these codes before I think with the original motor, but this is the first I've seen them in a good while. I'm having other weird electrical issues too so I hope this isn't all one big problem.
Ground somewhere could be an issue, but that should be an easy check between ground pin and another good ground. I'd just want to make sure before dumping $80 per sensor lol
Haha definitely. If I do need sensors I'm going with Denso's. About $100 for both of them.
Whwn I originally replaced all mine as well as the Y pipe I installed Bosch cause normally they make quality stuff. Nope. Avoid Bosch automotive parts all together. Everything I've had from them has been crap. Went with Denso's last year and it corrected all my exhaust codes. Still getting a misfire, I contribute that to the MSD wire set OR a faulty coil pack. The spark plugs are NGK Iridiums so I doubt it's those
Bosch wires and AcD plugs are a good combo. I think Denso O2 sensors are stock
I checked the fuses on Friday, and all of them are good. Same with the low beam headlight fuses. I'm completely lost on the headlight issue.
Does anyone know what these are? Do they have anything to do with the headlights? The one on the passanger side is just hanging around which is the side that my low beam won't work on. The one on the drivers side is a different color which is gray and it's snapped into the transmission cooler support. No idea if this has anything to do with my light problem? This is starting to irritate me...
    247.7k
    2.6m
    Jason Coe
    Jason Coe
  • Who's Online   3 Members, 0 Anonymous, 1,008 Guests (See full list)
