Daryl Z71's 2006 Silverado Z71 Re-build
Daryl Z71
My manifolds flange is cracked so i need a set of CARB legal shortys.
I saw a dyno graph from these DT's that showed an increase in HP & TQ. It was from a Camaro. Hoping it applies that way to the truck too. Edited by Daryl Z71
400hp and 400+ lbs/feet of torque would be nice setup with the 5.3's...
Would need semi-aggressive cam, ported ans milled heads, long tubes, and tune for that. Youre talking of adding almost 100 HP. Blower is cheaper than all the other stuff
Are those numbers relatively reachable with a 6.0?
And NA power or bust for me but cams, tune, and headers would be a good basic combination
In the 6.0, LS6 cam, a decent set of heads, headers, and a tune can hit 400.
I was referring to long tubes. Your setup and tune it is possible to hit that maybe 340. Dyno is subjective and ill let you do the math, but dyno after the swap said 325 at the wheels and it was just tune, intake, and MBRP exhaust made for the 4.8/5.3.
Got the engine pulled today. Turned out to be a pain in the ass. We started around lunch time and didn't finish until about 11pm. Have to make a parts run tomorrow for a serpentine belt, transmission seal, and a few bolts, but after that the new motor is ready to go in.
