tbi to vortec
Got tired of the oil leak and now a second set of head gaskets have gone to 5H!T (second set since november) so instead of pulling the motor to get to my rear main seal and oil pan gasket I bought a 5.7 vortec to swap
what all should I need other than a wiring harness differently
You need the engine worong harness, probably a new trans and the harness for that. The Vortec are OBD2 engines and yours is not.
Some companies may make kits, but after 96 all the wiring changed. If you already have the motor look at these
http://www.holley.com/types/HP%20EFI%20-%20Stealth%20Ram%20Systems.asp
http://www.holley.com/types/HP%20EFI%20-%20ECU%20&%20Harness%20Kits.asp
http://www.holley.com/types/Avenger%20EFI%20-%204%20BBL%20Multi-Point%20Systems.asp
http://www.edelbrock.com/automotive/mc/efi/pf2-chevy.shtml
http://www.edelbrock.com/automotive/mc/efi/pfxt-chevy.shtml
I would personally run a port system if you bought the engine already. One of these kits will make the install a lot easier for you and come with what you need
Yeah, but with that extra $$$ he can just buy a newer truck.
    247.7k
    2.6m
    Lukasz Chmist
    Lukasz Chmist
  • Who's Online   0 Members, 1 Anonymous, 929 Guests (See full list)
