Trwtow Posted April 7, 2014 Share Posted April 7, 2014 my high country ccsb 4x4 has steel Quote Link to comment Share on other sites More sharing options...
Spurshot Posted April 8, 2014 Share Posted April 8, 2014 (edited) With the reports I see, I'm going to check both sides to make sure they're both the same. I looked on one side today and the upper and lower were steel. March 2014 produced GMC crew AT 6 1/2 ft SLT 5.3L 4x4 Regarding availability of Z71 on the High Country, I noted that my GMC All Terrain package includes Z71. Edited April 8, 2014 by spurshot Quote Link to comment Share on other sites More sharing options...
Jay700 Posted April 8, 2014 Share Posted April 8, 2014 Waiting for mine too be built and show up before I order a leveling kit. Quote Link to comment Share on other sites More sharing options...
Plwtwo Posted April 10, 2014 Share Posted April 10, 2014 Anyone who has 4wd with Steel Upper control arms, and has removed them for a lift kit replacement or if you Would just like to have Aluminum Upper control arms, Ill trade with you! I need a set of steel uppers to use With Drop spindles, so let me know if u'd like to swap! Btw, we all should have aluminum lower control arms, i think since '05 GM has used the lower Alum CA, in 07 in was on all 1500 chassis (truck/suv 2wd/4wd). Iirc Quote Link to comment Share on other sites More sharing options...
Plwtwo Posted April 10, 2014 Share Posted April 10, 2014 PLWTWO, the reason you'd need new control arms is because if you press the stock bushings out you won't be able to press the cam bushings in that come with the drop kit. Aluminum makes it a one time press fit and therefore non serviceable for bushing replacement. Which ordinarily wouldn't be a big deal since they are non serviceable ball joints anyway. I wouldnt be pressing the cam bushings in or out of the CA, swapping the spindles, just the ball joint mount to the spindle (upper and lower), the balljoint would mount the same way to the spindle, with either CA. I was told its the force exorted on the Upper is higher then the aluminum control arm is able to except safely. So its a lawsuit avoidance stance, Mcgaughy even saidthey'll fit perfectly with no issue, we just feel it isnt safe in the long run. Quote Link to comment Share on other sites More sharing options...
racerkvn Posted April 10, 2014 Share Posted April 10, 2014 FWIW, my 2012 4wd, 2013 2wd and 2014 4wd all have steel upper & lower control arms. Quote Link to comment Share on other sites More sharing options...
2017SierraSLT Posted April 10, 2014 Share Posted April 10, 2014 Anyone who has 4wd with Steel Upper control arms, and has removed them for a lift kit replacement or if you Would just like to have Aluminum Upper control arms, Ill trade with you! I need a set of steel uppers to use With Drop spindles, so let me know if u'd like to swap! Btw, we all should have aluminum lower control arms, i think since '05 GM has used the lower Alum CA, in 07 in was on all 1500 chassis (truck/suv 2wd/4wd). Iirc My '13 Z71 has cast iron upper and lowers. Quote Link to comment Share on other sites More sharing options...
Plwtwo Posted April 10, 2014 Share Posted April 10, 2014 FWIW, my 2012 4wd, 2013 2wd and 2014 4wd all have steel upper & lower control arms. Wow, I guess GM doesn't hold conformity to close to heart. I stand corrected. Every one that has came thru my shop has had aluminum lowers... I currently own a '12 & a '13 and 2nd '14 all with aluminum lowers. Had '2 '05's, '07 and they had aluminum lowers. GM just doesn't make sense, no wonder they had cash flow issues. My '13 Z71 has cast iron upper and lowers. Can you take a pic- haven't seen cast iron control arms. Quote Link to comment Share on other sites More sharing options...
2017SierraSLT Posted April 10, 2014 Share Posted April 10, 2014 (edited) No, they are the iron/steel ones that 75 percent of them have... Edited April 10, 2014 by 2013sierrasle Quote Link to comment Share on other sites More sharing options...
racerkvn Posted April 10, 2014 Share Posted April 10, 2014 Quote Link to comment Share on other sites More sharing options...
J-man67 Posted April 10, 2014 Share Posted April 10, 2014 (edited) Deleted! Edited April 10, 2014 by J-man67 Quote Link to comment Share on other sites More sharing options...
SY2455 Posted April 14, 2014 Share Posted April 14, 2014 Mine has steel upper and lower. Quote Link to comment Share on other sites More sharing options...
jcchevy Posted April 18, 2014 Share Posted April 18, 2014 3 Aluminum upper /lower and steering knuckles - denali 6.2l 4x4 with z71 option. Yes they are used to reduce overall weight(42lbs in total) for crew cabs at higher trim level and specific options Quote Link to comment Share on other sites More sharing options...
pancepance Posted April 19, 2014 Author Share Posted April 19, 2014 Im going up to the dealer in a few to look for myself since the truck arrived the other day. I will certainly provide whatever info I can get from my specific truck. Maybe at some point we will be able to determine the exact style/options that get which parts. The ppl. at bds were super cool. They were going to let me get one complete kit and then also get the other type of knuckles/arms so that when the truck arrived I'd have the parts I needed either way and I could return the ones I didn't need and not pay any fees or shipping charges. I figure that was more than fair offer. Only thing left to do is decide if I want the truck or not. I'm really soured by the way the incentives and pricing issue is being advertised. Spent 3 days trying to get straight answers and still unable to. Its to the point of principle. The plan is to go see the truck in person today. If they can explain to me all the details of advertised prices, incentives, etc. I'll buy the truck. If I don't get a good feeling from their explanation I'm going to say thank you for your time, and get something else. I don't like being treated like a fool. I especially don't like when someone tries to bait and switch me. If that's what I come away with I'm walking for sure. Either way. I'll check knuckles and arms before I do. Quote Link to comment Share on other sites More sharing options...
TX14Z71 Posted April 20, 2014 Share Posted April 20, 2014 (edited) I have a CC LTZ Z71 standard bed with steel. I read the following in another forum. "Any time you have two dissimilar metals in contact with each other, there will be some degree of galvanic corrosion. (It's actually the principle that makes batteries work.) The parts can end up 'welding' themselves together. (and yes, salt helps that process along) So that's why you always use an anti-seize compound when you put steel (or stainless) fasteners in to an aluminum part." Edited April 20, 2014 by TX14Z71 Quote Link to comment Share on other sites More sharing options...
