Passenger door will not open from inside?
When i pull the handle, the lock button pops up but the door doesn't open, it doesn't feel like there is any connection with the rod to the latch mechanism. Normally i would not be too concerned and would drop off at dealer for the warranty work, but the question i have is this. I installed the pop n lock tailgate power lock and i want to make sure the new trucks are the same as the old as far as door opening being mechanical and not electrical. If they are electrical then i may have screwed something up with the install of the pop n lock, which has been installed for 700 mi by the way.
So are the door latches good old fashioned mechanical or new fangled electric?
Thanks
Kevin
You have to pull twice if the door is locked. Sent from my LG-G2
Yea, i saw that while i was checking out the other side. I was looking for a "child proof" lock out switch type thing (there was one on my Avalanche and Tahoe) on the door but couldn't find that either.
Lockout switch is on drivers door. One for windows only, one for doors. Sent from my LG-G2
found that, passenger side works normally
But, did that open your door or are you still stuck inside.
still laughin....
passenger side door works fine
