Which Engine Oil?
  • Replies 63
Here is a list of dexos1 oils. You can use any of these.
There are some companies out that are not on the list but their oils meet the dexos1 specification, AMSOIL is one of them and so is Valvoline.
Obviously I don't have a new 2014 model but if I did I would be using AMSOIL of course.
Is 0w-20 or 5w-20 better?
The manual says only to use 0W20 in the new 5.3 and 6.2. The only new motor that uses 5W30 is the 4.3.
Stick with the 0W20 and keep that extended warranty you bought in good standing. :thumbs:
I had my truck in the dealership for safety recall bulletin and an oil change. I told them I would pay for the oil change as the DIC was not at 20%. The truck has 3,400 miles and I wanted the oil changed for the first time anyway. The dealer said I could use one of the "free" changes, as GM decided to drop the 20% requirement due to a lot of complaints. I didn't know about the change of policy (if it is true that is) but you are entitled to the free changes until used up (or mileage limit reach).
