12v Accessory Power Outlets
Test truck is a Sierra SLT for a product im doing. I need a 12v constant hot. On my personal 04 Sierra I am tapping the 12v outlet.
So the question is, is there a 12v outlet in the upper storage of the jumpseat, and if so how do I remove it and the one on the dash?
  • 2 months later...
Has anyone converted their dash outlet from 12v battery to switched power? I tried to search for this topic with no luck. I'd like to have this outlet on switched 12v power so I don't have to unplug my radar detector every time I get out. I know there's options on other GM vehicles for this but I haven't found any info for this on the 14's. Thanks !
Page 9-29 and 9-30 of the Silverado Owner Manual says...
Accessory Power Outlets (APOs)
The vehicle may have APOs in
several locations. See Power
Outlets on page 5-6.
The APOs in the console or center
seat position are powered by RAP (Retained Accessory Power).
They will continue to work for up to
10 minutes after the key is turned
from ON/RUN to LOCK/OFF, or until
the driver door is opened.
The APOs on the center stack come
from the factory powered directly
from the vehicle battery, and supply
accessory power at all times,
regardless of ignition key position.
If electronic items are left plugged
into these APOs for long periods of
time with the vehicle off, the vehicle
battery could be drained. The
vehicle may not start if the battery is
allowed to drain for an extended
period of time.
The source of power for the APOs
on the center stack can be changed
from direct battery power to RAP by
moving the fuse at location 10, in
the left instrument panel fuse block,
to position 11. Once the fuse is
moved, the APOs will continues to
work for up to 10 minutes or until
the driver door is opened. See
Instrument Panel Fuse Block (Left)
on page 10-49 or Instrument Panel
Fuse Block (Right) on page 10-52.
If you are not comfortable
performing this change, see
your dealer.
I hope this helps
no problem. I remembered reading it somewhere - I keep a small rechargeable LED flashlight in the console and needed to make sure it was RAP so that it will not drain battery. I keep a PDF copy of the manuals on my laptop which I can easily search...cheers
What is the center stack? I have a console so does that mean the one inside the console is rap and the two near the dash by the switches is on all the time?
The fuse block referenced above is located in the left dash. Open the drivers door. It is located in the end of the dash with the door open. If you need more info, check Owners Manual page 10-49.
