2014+ Intakes (CAI) & Air Filters
Thanks. Do you have a link to the results? I have been looking for data everywhere, I heard that it was good but Blackbear Performance told me that that Airaid Jr had zero impact on performance during their dyno tests of CAIs.
1 hour ago, bsprtsgrp said:
The Dyno results are very good with the stock OEM Airbox with a K&N drop-in filter and the Airaid MIT.
OK, now I get it, so this is stock filter with Airaid MIT but there used to be with K&N drop-in. Now I understand.
Just now, bsprtsgrp said:
it's not showing the MIT & K&N drop-in data any longer...it's just showing the stock OEM set-up
the Air Raid JR works great, the reason there is no improvements is because there is a restrictor panel inside the OEM airbox next to the fender, so airflow will not jump up unless you pop this piece out.
Edited by flyingfool
  • 3 weeks later...
American Trucks did a video showing the gains from an AirRaid MIT only on a 14 Silverado. Seemed to make a small difference. I am probably going to throw one on and keep my paper filter.
10 hours ago, flyingfool said:
at the 6 minute mark the moron kid, sprays lubricant oil on the MAF sensor. insane... how did they get 20 hp? lol everyones a sales man these days
it isnt 20hp to the wheels it is from the curve gain
45 minutes ago, flyingfool said:
what's curve gain?
He explains it around the 0:45 sec mark of the video. Basically it's the gains in efficiency showing up with better throttle response, better acceleration. Since the top end HP doesnt change much just from the tube, this will be the difference you feel. It is the highlighted area in this picture.
when i get free time I can data log the intake manifold pressure and the MAF sensor, before and after.. with the stock vs the Air aid JR.  vs restrictor panel removed , then swap in a 6.2 TB and 6.2  manifold.  would make for a cool thread here one day
Dyno, otherwise you've got nothing.
There's no indication of what dyno it was, correction factor etc. They fabricated that chart
