Ezekiel2517 Posted October 8, 2013 Share Posted October 8, 2013 Can anyone tell me which bulbs to buy to just get more light in a GMC SLT? I had GE nighthawks in my old truck and apparently got spoiled because these lights are very dim in comparison. After reading through all the threads I don't know if a 9006 or a 9012 bulb is the answer. Can I just go get some Nighthawks and drop them in? Thanks! 1 Quote Link to comment Share on other sites More sharing options...
diggerdan11 Posted October 8, 2013 Share Posted October 8, 2013 Sylvania Silverstars Ultras are pretty nice. I also have Silverstar zXe's and they are great, they are very bright and they give you a slightly bluer tinge than the ULTRAs 2 Quote Link to comment Share on other sites More sharing options...
ibleedgreen Posted October 8, 2013 Share Posted October 8, 2013 I'm interested as well. I can tell you that you have to modify the 9006. I bought the Sylvania mentioned above and the tabs are just a little off. I got the H11 for the fogs but haven't had time to try them. Anybody else get any bulbs to fit? Quote Link to comment Share on other sites More sharing options...
Carder09 Posted October 8, 2013 Share Posted October 8, 2013 Look up GE nighthawks. Brightest bulb you can get without hids. The sylvanias are garbage Yellow light with a blue tint on it to appear brighter. Quote Link to comment Share on other sites More sharing options...
crushNchowda Posted October 10, 2013 Share Posted October 10, 2013 Sylvania silverstars or philips crystalvision - I found the crystalvision lasted longer and looked more like "HID" Quote Link to comment Share on other sites More sharing options...
Ezekiel2517 Posted October 10, 2013 Author Share Posted October 10, 2013 Thanks for all the answers. But the question remains -9006 or 9012 and what has to be done (if anything) for them to work? 1 Quote Link to comment Share on other sites More sharing options...
ibleedgreen Posted October 10, 2013 Share Posted October 10, 2013 Thanks for all the answers. But the question remains -9006 or 9012 and what has to be done (if anything) for them to work? lmao, that's what I'm saying! Is there a 100% direct swap for the headlight and/or fog light? I know the 9006 is not a direct swap without modding it. Quote Link to comment Share on other sites More sharing options...
MotoMedic Posted October 11, 2013 Share Posted October 11, 2013 9012 - no modifications 9006 - slight trimming of tabs (which can easily be done with set of wire cutters or small file/blade) 1 Quote Link to comment Share on other sites More sharing options...
Ezekiel2517 Posted October 11, 2013 Author Share Posted October 11, 2013 Thanks. Does anyone know what bulb is currently in this truck to compare lumens or whatever brightness standard they use before plunking down money on a new bulb? It appears that 9012s are HIRs and 9006 are standard bulbs. Is it possible that 9006s could be brighter with the right bulb? Or would a better 9012 be the way to go. The only 9012 I can find that looks like a possible improvement is a phillips but it is pretty expensive Thanks Quote Link to comment Share on other sites More sharing options...
eclou Posted October 11, 2013 Share Posted October 11, 2013 why not just do an HID conversion? Companies like DDM tuning run $30 per side for a 35w 9006 kit Quote Link to comment Share on other sites More sharing options...
Ezekiel2517 Posted October 11, 2013 Author Share Posted October 11, 2013 One other question: I read that only hi beams work on this truck and that low beams are controller by a shutter. This is evident by the distinct line drawn where the low beams end. But this line is so close to the vehicle that traveling down unlit roads at night is kinda scary on low beams. Is there any way to adjust the height of this shutter to shoot the low beams a little further? Quote Link to comment Share on other sites More sharing options...
Ezekiel2517 Posted October 11, 2013 Author Share Posted October 11, 2013 I guess I had assumed that HIDs would be much more expensive and PITA. I may look in to them. I miss my plain Jane old headlights :-) Quote Link to comment Share on other sites More sharing options...
clayp Posted October 11, 2013 Share Posted October 11, 2013 The kits nowadays are plug and play for almost any factory bulb type. The only thing you need is some double sided tape to mount the slim ballasts. Most of the issues with aftermarket HID has been with crummy light dispersion when plugged into a non-projector housing. Fortunately the Sierra comes with projectors stock! Quote Link to comment Share on other sites More sharing options...
ibleedgreen Posted October 11, 2013 Share Posted October 11, 2013 I trimmed(very simple) a 9006 Siverstar to test last night, bulb seemed much dimmer than stock. Quote Link to comment Share on other sites More sharing options...
