2014+ Grille Removal How-To
  • 1 month later...
  • 5 weeks later...
I've lost my previous phone. The phone was wiped and the pics got erased, so now there is no association for the links to display. I doubt I can bring them back but I'll see what I can do.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Edited by anthony2558
  • 2 months later...
  • 3 weeks later...
  • 3 months later...
  • 3 weeks later...
Tried taking my Sierra grille off today and was having some difficulty with 1) trying to locate the 2 bolts located "under the headlight" (access from underneath the truck) and 2) removing the bumper pad - which way do I pull or methods for easy removal?
Thanks in advance... This writeup is great but different for the Sierras
  • 1 month later...
REMOVE SNAPS
REMOVE SHROUD
REMOVE TWO NUTS WITH 7MM
LEAVE HEX SCREW
START TO PULL FROM SIDE AND LOWER LIP
UNDER TRUCK YOU WILL SEE 4 OR 6 CLIPS, CANT REMEMBER. LIGHTLY PRY AWAY
BUMBER LIP REMOVED. BE CAREFUL NOT TO DROP. ONCE CLIPS WERE REMOVED IT FELL RIGHT OFF.
REMOVE 4 ON BOTTOM AND 4 UP TOP 10MM
REMOVE AIR DAM. AND REPLACE ON TO NEW GRILL 7MM
AND YOUR DONE.
1 HR START TO FINISH FOR ME.
Hey anthony2558,
I joined this forum specifically because I wanted to ask you about your grill. I've purchased a T-Rex grill for my 2014 Silverado LT Rally edition. PN 6311211.
My truck with the Rally package comes with black inside grill honeycomb already.
Upon trying to install the T-Rex I discovered that my stock grill does not have the removable honeycomb portions. The black portion above and below the bowtie are all one piece and the honeycomb cannot be removed.
I spent the better part of $1500.00 on this grill so now I need to get a grill to install the T-Rex inserts into.
Was your grill you bought an exact fit for the OEM slot?
I'm hoping I can buy the grill you bought and throw the T-Rex inserts into that.
What are your thoughts?
And sorry to resurrect a dead thread everyone.
Thanks
Hey anthony2558,
Thanks
What's up man. It's good you found this thread instad of starting a new one. [emoji106] It's been a while since I did this install. From the pics, and what I can remember the honeycomb was removable. I remember people swapping out the inserts, and websites were selling custom inserts also.
Maybe someone else can chime in to confirm this. It's been a while since I looked or even had the Silverado.
    247.7k
    2.6m
    Brent Wylie
    Brent Wylie
  • Who's Online   3 Members, 0 Anonymous, 620 Guests (See full list)
