2014+ Lowering / Drop Kits
17x9.5, designed for GM trucks but doesn't fit this body style without a 1/4" spacer. Until the small brake kit goes on for a 15".
I'm getting my rear Vikings soon. And I found a bolt in coil over mount for the front so I'll be getting viking up front as well
Got a link to the mount? Edited by Darth_Vader
I didn't have time to read through all the pages.
I've got a 2016 1500 crew cab 4x4. Looking for a 2/4 or 3/5 drop. Don't want to mess with the driveline. Does not appear to much out in the marketplace. I do want to be able to tow and would prefer a bag setup in the rear. Anyone have any input? TIA.
Reggie
I have a 2/4 Belltech kit for sale if you're interested.
Got a shot of the QA1's last weekend. Had to use a couple of washers and grind down a bit off the mount so it wouldn't hit on the bottom but you get the idea. I'm running about 4 on the setting and it matches the McG's up front well. I prefer them at a 3 or 4 but the back gets too soft. I'll eventually switch the front to QA1 coilovers.
Darth- do you have a part number? I've got my factory shocks with extenders for my 5" drop and it rides ok, but I want to be prepared for when they blow out.
I noticed this today. Looks like I need to pull the shafts and have it shortened
Had the same problem, thus why I went with the aluminum aftermarket unit, go ahead and replace that output seal as it will start leaking soon.
I used the TS709 (S being single adjustment, TD709 is dual) but I highly suggest you measure your compression and stroke to verify that they are in the same range. The TS709's are 19.5" extended, 12.8" compressed.
