2014+ Lowering / Drop Kits
So if I measured everything correctly, Im having to replace my 2* shims with 4* shims. Gonna do it wednesday. When I look at my truck the rear sits lower than the front with the 2" shackle and block removed. If I still have any vibration issues after the swap Im taking it to a driveline shop and letting them measure everything out.
Now im really considering getting spindles for the front. Im really digging the lower front. My only concern isI dont know the torque specs for the upper and lower control arms and tierod ends. Does anyone have that info?
Mcgaughys provides torque specs in the instructions.
RT
Used the McGaughy's 34170 adjustable kit, and used the 4/6 option. It comes with struts and rear shocks. The rear bump stops were a pain. I have 24" Versante 228s in chrome. We originally ordered 295/35-24 Nexen tires, but they were way to big. Putting 275/30-24s on them. Will put updated pics once they are mounted this weekend.
I have a quick question. My truck is lowered 4/6 currently. it's got 2in drop spindles and 2in drop shocks in front. And rear flip kit with 6in lowered in the back with have 5-7in belltech drop shocks. the shocks have a maximum limit of 7in drop. I can only go 1 in lower in the back. Would 1in drop shackles work fine? Is there any way to go lower eventually? Later on I want 5/9 drop. And I know im going to have to notch it
So I got my Mcgaughys spindles in and plan to install them this week. Anyone know if I need any special socket or bit to remove the caliper or anything else? Do the front rotors come off easy or do they need a bolt to torque them off the hub?
