2002 Ext Cab Dropped Rear
  • 5 months later...
  • 4 weeks later...
im doing 2in belltech shackles on my 02 ext cab can you guys give me some install tips and some does and donts so i can make this an easy swap! can this be done in a couple of hours?
I want to do this to my 03 and have the same questions. :cheers:
Jack up the back of the truck. Put it on stands so that the rearend will hang down. Put the jack under the diff and apply a little pressure. Remove the bolts for the shackle replace it with new shackle. It's a pretty easy thing to do.
You should also pull the bushings out of the new shackles and coat them with lithium impregnated grease. this will increase the life of the bushings. You can get small tubes of it from any autoparts store. Also, when you install the new shackle, DO NOT fully torque the bolts until the truck is off of the jack stands. If you tighten them while the truck is up, you will pre-load your suspension, and it will squeak like a MOFO everytime you hit a bump.
    247.7k
    2.6m
    Tony Best
    Tony Best
  • Who's Online   0 Members, 0 Anonymous, 1,087 Guests (See full list)
