i am needing some help finding a noise and grinding sound in front end
so far I had to replace the front drivers side wheel hub and since then I have put in a new cv shaft and new sway bar kit and before the hub went out I had replace the upper ball joint and now I have a grinding sound and when I looked at my rotter I saw that it is starting to where on the top edge now and my break pads are chiped off the top corner also I put shock exstenders on and realized that the shock on the passenger side the top cushion is gone and when I put in to 4lo it gets worse I am lost I don't want to waste anymore time or money so can you help me im open for anything
