Alldata - Can somebody look something up for me?
Mossyoakglock
Does anybody have an Alldata account and be willing to look up something for me? This would be for a 2005 Audi A4 1.8T Quattro.
I need the torque numbers for the rear Coolant Flange studs/bolts and also the bulb diagram for the rear tail lights. Whoever had the car before us put two different style bulbs in the rear brake lights and I'm not sure which one is correct and I can't find anything online or in the manual. Audi's are tempermental when it comes to wattage and the bulbs and I want to get the right one.
Would somebody be willing to pull that information for me if they have an Alldata subscription?
Thanks, Dave! I knew the flange wouldn't take much and I didn't want to over-torque it and break the plastic.
Would there happen to be a diagram of the rear lights? On the driver's side they put a 7506/1156 but in the same spot on the passenger side they put a different model number that has a different wattage. I think they might have done this for other bulbs and want to make sure I have the right bulb in the right spot. There are multiple tail/brake bulbs on this car too.
The owner's manual is useless as it says please see dealer under bulb replacement.
Yeah i'm familiar with VAG and the wonderful way they design cars. Is the Audi an AVANT, CABRIOLET, or BASE? The bulbs are different for each one so i need to know which one it is so i can get the correct guide.
If its a base model then the 7506/1156 is the correct bulb for the brake bulb. 7506 for the back up bulb, 5007 for tail light bulb, and 7507 for rear turn signal.
I couldn't find much in shopkey but here is a quick little right up i found with a quick google search. Hope it helps.
http://www.audizine.com/forum/showthread.php/84054-B6-A4-DIY-Rear-Coolant-Flange
