Post Pics of Your 2014+
2 hours ago, no12nv said:
here is my 2017 1500 . borla cat back s-type, 1" throttle body spacer, pedal commander, ranger afm mode delete, bush wacker fender flares
Edited by no12nv
1 minute ago, no12nv said:
here is my 2017 1500 . borla cat back s-type, 1" throttle body spacer, pedal commander, ranger 4cyl/eco mode delete, bush wacker fender flares
i need a lift guys .. not sure on what to do. i want to run fuel d509 deep lip 20x12 on toyo at2 extremes or nitto ridge grapplers. i hope to run 33.5 or 34 x 12.5s my front sits exactly 2.5in lower than rear. i can change rim size to a 20x9 with less offset n less lip. what do ya'll think would be best lift for what i want without going crazy? i was thinking 3.5 front n 1 rear? would that work? thanks
sorry posted in wrong section can someone move it pls. not sure how to
How'd you fit the light bar behind your grille?
I removed the grill shutters and mounted the light bar on bottom. I found a video on YouTube where the guy left the grill shutters on and just removed the lower half to keep the check engine light from coming on.
So no cutting or anything besides removing the bottom grill shutters? What mounts did you use?
Good to know, thanks. Do you have a link to the kit you used? I see a double row and a single row version on RCs website
Behind grille
https://www.roughcountry.com/30-inch-curved-led-light-bar-72930drl.html
Lower bar
https://www.roughcountry.com/30-inch-led-light-bar-70730bl.html
Met up with some friends from NY (total coincidence) in Corolla, NC.  We had a 4 car caravan rolling down the beach, 3 from NY and one from SC.  None of them had ever driven a beach before, and were quite glad they heeded my advice to air down.
