What would cause this?
Well I finaly got around to adjusting my lash on my 454 for my '61 apache. Every rocker arm set with no problems but the #2 piston's push rod on the intake valve acts like it is hitting the piston. I adjusted the rocker arm about 50 different times to see if I could get it right. The intake is not on the engine so Im sure that Im on the back side of the cam lobe. Can anyone help me fix this? Thanks
Alex
How are you tightening the rocker arms?  Like whats your procedure?
You shouldn't be opening the valve at all while your setting your lash.  As long as your lifter is riding on the base circle of the cam, it shouldn't matter what pushrod your using.
Also, if your using roller rockers and not stamped steel rocker arms... check to make sure your "trunion" (the middle of the rocker that rotates and slides over your rocker stud) is not flipped upside down.  Its common for the trunion to be machined on one side, and not on the other.  The machined side should be facing up.
Describe how your tightening your rockers and setting your lash. :crazy:
Sounds like your doing things right then.  If the rocker arm looks like its too high on the rocker stud, double check to make sure the trunion isn't flipped the wrong way.  Otherwise thats the right tightening procedure.
I don't understand whats seems wrong?  Can you not make that 1/2 turn to tighten the rocker nut then?  Like the valve is frozen and the valve won't go down just a little bit while your tightening the rocker nut?  If so, its got to be one of a few things.  Either the body of the rocker arm is touching the spring or retainer, or the body is touching the rocker stud.  It isn't very likely that the valve would get "tighter" in the valve guide.  It will get looser the more miles the motor has.  It could also be your valvespring.  If you hit the valve (not the spring) with a soft hammer, will the valve drop down a little bit, just to check that the spring or valve isn't the problem?
Alex, has the engine ever run before?  Was this engine just built?
If your having PTV (Piston To Valve) clearance now, and you didn't before, something has changed.  Assuming the engine ran or turned over fine before, and doesn't now, you had to have either put a higher ratio rocker arm on (like go from a 1.7 to a 1.8) and you didn't have PTV clearance to do that, you milled the heads or changed heads, you put a higher lift cam in, your timing is off, or you have a bent valve.
If your suspect of valve hitting the piston... take the rocker arm off that one valve and try to turn the motor over.  If the motor still won't turn over, you know its not just that valve or rocker arm.
Another huge possibility is if you have the timing marks off, the valves are opening at the wrong times, and that could easily be your problem.  I'd double check the timing.  The more I think about what you wrote above, this is what I think the problem is.
