Hollis092's 12' White Diamond Bulid
hollis092
  • Replies 75
  • 3 weeks later...
Latest update, windows tinted - front to match rear and add a nice strip on the windshield.
Guys did an amazing job and took less than 30 minutes or so.
Might have time to do the level install and have an alignment done next week. Then on to ordering the new shoes - most likely Zeon LTZs or Grabber AT2s.
Level installed today.
Before:
After:
This was the 2.5" TGC - Top .5" spacer, lower 2" spacer.
Easy install, but wanted to give my notes.
1. First, after removing wheels and tires, remove upper strut bolts (18MM)
2. Loosen UCA ball joint - leave nut on bolt about 4 threads (tap knuckle to free)
3. Loosen Sway Arm nuts/bushings, but do not remove completely
4. Loosen steering linkage nuts (21MM) - do not remove completely (tap knuckle to free)
5. Remove lower strut bolts and retaining clips (retain this hardware if you want to return to stock)
6. Slide out strut and place spacer on top
7. Insert strut back into place and tighten upper strut bolts
8. Moving to the bottom, slide the lower spacer in and use a bar to pry the strut on top of the spacer
9. Have a bolt ready to slide into place, once aligned the bolts will fall into place.
10. Tighten upper and lower strut bolts to mfg specs
11. Tighten the UCA, steering linkage, and sway bars back to spec
12. Repeat for other side.
If your going to eventually go to a 4" suspension lift, make sure you get the wheels you would want for that lift. I bought another set of wheels two years after I got my M/T II's. Now Im looking at going with a 20" wheel with 37" Toyo M/T's wrapped around them. These damn trucks are an expensive hobby...
I'm actually looking around at different wheels at the moment also.
Toying with the idea of a mix of black and chrome or just sticking with chrome... can't really decide, but the black/chrome ones I found look amazing.
