Adding Aftermarket Sub/Amp
Anyone run something similar to this? http://www.crutchfield.com/p_20611PS10C/Kicker-11PES10C.html?tp=114
I'd eventually like to add a sub. Had a large enclosure and a RFosgate P3 in my last truck but I don't want to waste that much room in this one. Looking for something small to fit under a single seat. If I do go the route of separate box/amp probably mount the amp on the back wall.
You are going to need the blue positaps. I used them in my build
http://www.gm-trucks.com/forums/topic/168513-diy-2014-silveradosierra-non-bose-complete-audio-upgrade/
I think the ones I used were black. The OEM subwoofer wires are considerably thicker than the rest of the normal speaker wires. Nice products tho, super easy to use.
Ah, I missed that part. The blue posi taps are adequate for the speaker wires. Not sure on the sub wires.
No probs.
For people wondering, the black posi-taps will work on the subwoofer wires.
I'm just about to start the kicker sub install on my 2014 Denali with Bose. Should I use the brown/blue-stripe and blue wires from the factory harness that they say I should use in the instructions, or should I connect via the Bose amp wires like you guys did?
I've almost decided on my sub/amp set up but I am wanting to post my wiring diagram for someone to double check. I think I've got it right. Open to suggestions that would make it better/more efficient. For those that are running the LC2i... where are you wiring your 12v power? Thanks.
Edited by tootall87
