Adding Aftermarket Sub/Amp
I have a 2 channel amp and I did hook up one channel to the Sound Ordinance power sub but I am a bit disappointed. I hear that if I hook up the other speaker or "bridge" the connection it should be better. So far it sounds like some body farting in the back seat... Crutchfield has been zero help to me. Told me I had to buy an audio controller when I didn't need it. My SO B-8PTD has both high and low level inputs.
It's all about the dollar for them... IMHO!
anyone know the ohms of the stock speakers, and if its possible to just replace the stock amp? i don't want to run power and all that junk, i'd just like the speakers to sound cleaner.
Anyone have any thoughts on this? Are the stock non-bose 8" display speakers any good? would they benefit from an amp? or would it be necessary to do amp and speakers?
are there 6 speakers in a crew cab no bose? dash and doors only or are there speakers behind the back seat? i cant really get back there to see because im in a wheelchair. and what size if u know?
There are 2 tweeters on top of the dash, then one in each door.
On the 2014 Silverado Crew Cab non-Blose, front doors are 6x9's, rear doors are 6.5", dash speakers are 2.5" drivers.
just following up....special shout out to AW22 and T gleason for replying to my query. We tapped into the wiring for the existing BOSE sub and no clipping/feedback yet (yet since I only drove it from the shop to home, not nearly enough time or speed to determine if its an end result). We are assuming that the ANC programming/software accounts for the subwoofer and disregards the sub output. Basically we are hoping the engineers took the subwoofer into consideration when designing/implementing the ANC system. Then again these are the same people that cant get a drivers seat to sit firm so not much faith is warranted or deserved. I will report back if there is a change on the off chance someone else finds themselves in a similar situation. Now I need to start saving for my next upgrade (either a 4-5" lift or a tonneau cover and bed rug).
Any more feedback you can give? I just finished up my install and I've got a bit of noise while driving but none at idle. I hooked into both rear speakers using PAC LP7-2.
As I stated we tapped into the Bose sub for the signal. Do you have the speed volume control on? If so cancel it and see if that helps. The option is in settings. I know when that's on the mics are very sensitive. Maybe that will sorta turn off the mics? Worth a shot. I wouldn't be surprised if the ANC is causing the noise especially since its quiet in idle.
I will say that my back door speakers are weaker than I remember hearing them...most likely I just never paid attention.
  • 3 weeks later...
Forgot to mention which power source I used for the amp's remote on....
If you look under the driver's side dash between the brake pedal and parking brake, you'll see the fuse/relay box (it's about 6" x 10" and has a smooth black plastic cover, just like on the GMT-900's). Pry the clasps on each side to remove. On my SLT there are three main banks, left to right, with the first being unoccupied (see attached pic). The slots within first bank are labeled 1-20, though only 11 actually have male connectors. I used my tester to determine the following: #'s 7 & 17 are constant 12v power [always on], #'s 10 & 11 are grounds, and #8 is the RAP [retained accessory power] ignition signal wire (again, see attached pic)
For newbies, RAP powers on with the key rotated to the first position and remains on until the ignition is turned completely off AND the driver's door is opened, just like the factory radio.
Enjoy!
Thanks for this.
Edited by 05cyclone
So i solved my own problem. I used Motomedic's wiring scheme to wire my remote wire with the smallest female connector i could find. Works great. Finally finished my little system. Single Sundown SD2 10 and sundown SAE-600d. Sounds awesome.
Can someone point me to the pictures showing the Bose amp (behind the seat) and it's wiring connectors? I think it was labeled showing which wires were which. . I have looked everywhere and can't find it.
Thanks!
Thanks!
I'm not sure where the picture is, but the Bose amp wires are the only thick blue wires that are twisted together. They run along the passenger side.
Thanks. I did find the posts:
http://www.silveradosierra.com/mobile-electronics/2014-sierra-w-bose-adding-amplifier-speaker-level-t107898.html
After a few weeks of trouble shooting I found the supplied power wire from Crutchfield was in need of a little tweaking. The fuse holder is nothing but a couple of wire connectors inside a waterproof housing and after measuring the power input to the sub from the wires and finding it NOT to be a constant 13v I carefully pinched them tighter with needle nose pliers and now all is good. No wonder they gave this crap to me with the purchase of the sub...
