2014+ Leveling Kits
Mine is finally done! After months of research I went with the RC 2.5" level kit front only, stock rear block. 20"x9" Fuel Nutz w/ +1 offset, 33x12.50x20 Toyo M/T tires. No rubbing, No trimming, yet anyway. It is perfect for me. Just what I wanted.
Perfect! :thumbs:
  • Like 3
Truck Setup: Double Cab Standard Box LT Z71
Pre lift measurements:
Front: 36"
Back: 39"
Rake: 3"
Name and style of kit used: Pro-Comp 1.5" Front Level
Post lift measurements:
Front: 37.5"
Back: 38.75"
Rake: 1.25"
Right where I want to be. Enough rake that I can still load the bed and haul a boat without driving nose up.
2.5" rough country leveling kit
-2.5" gain in front
-1" gain in rear
275/70/18 BFG all terrain tires
Replaced the wheels also since belletire gouged my factory wheels and offered the rims at cost.
Installed a 2" RC levelling kit today and had the truck aligned… Just running the stock tires for now, but planning on new rims and tires before the new year… Just might not be able to put them on till next spring depends on when I get them…
I don't recommend any levelling kit over 2.5", the suspension and driveline angles will be really bad… That my opinion thou… Rough Country make a 3.5" kit that fixes some of the issues with a new UCA and diff drop brackets, but even it's angles are a little to much I find…
I don't recommend any levelling kit over 2.5", the suspension and driveline angles will be really bad That my opinion thou Rough Country make a 3.5" kit that fixes some of the issues with a new UCA and diff drop brackets, but even it's angles are a little to much I find
Thanks man..Probably just going to go with the Topgun 2.5.
Have you had any rubbing now that the components have settled? Even at full lock in reverse? Curious because a really want to run 305 but I don't want any rubbing on a brand new truck. Thanks
