2014+ Leveling Kits
I guess both, more so tall just to fill in the wheel well as much as I can but don't want the wheel sticking out the size much past the stock.
I installed my 2" RC level kit yesterday, it took me and a helper about 1.5 hours.
I removed the wheels (and the lower strut bolts of course) and loosened the sway bar bolts only leaving about 2 threads holding it on. Those the only bolts I touched, I didn't loosen anything else. Managed to get the blocks in place by prying, tapping with a plastic hammer, and using a tapered punch to get all three holes lined up.
My front wheel well height was 36 1/2" before, and now it is 38 5/8". Front is now 1/8" lower than the rear, so it worked out well.
Getting some 33" tires put on later this week!
The rear is only 38 3/4" ? The rear on my Z71 before tires is 39 1/2". It is 40" now with the 33s.
Yep, I have a dual liner in the bed, and a low profile aluminum tool box, and inside the box is probably close to 100 pounds of tools/stuff. (And a full tank of gas when I measured! lol)
So there is some added weight that is probably dropping my rear end a bit. It does seem like every truck sits at a different height though.
Here's my install from today.. I went w/ the 1.5in leveling kit from McGaughy's.. Overall decent parts, but you'll need new bolts!! The factory nuts will NOT work and will only go on a few threads.. Luckily, I had extra bolts from years ago in the tool box that work prefect!
Its 39inches in the front and 40inches in the back. Really dig the new stance! Bigger tires are up next!
  • Like 4
Nice looking truck!
Pro Comp 2.25" Leveling Kit w/ Cooper Discoverer STT 33X12.5R20
Edited by TXSierra507
Looking for the ready lift kit that gives 2.5 in the front and like a 1-2 inch block in the back? Just to recover some rake.
Edit: found it if anyone else was interested part 66-3002 and 66-3085
(Anyone have pics with this setup(
Edited by Nemo39
