Ok, so I swapped my 22's (Bridgestone Dueller A/T RH-S) for my 18's (Goodyear Wrangler SRA with the whit outline, not black) and did a fair amount of driving today here are my impressions:
The 18's lead to a very "floaty" feel of the ride, the road noise is also increased. The ride doesn't really seem to have changed at low speeds, the truck still has a light vibration, once I hit about 40-45 or so up to about 55-60 the vibration became much worse, even worse than the 22's, and a couple time the truck started to shake/ rock to either side. my truck has never done this before. above 60 mph or so, the vibration is about equivalent to the 22's.
a second thing that happened was the TPMS system stopped working, when i swapped them yesterday, it was fine as was the case for the first 45 mins or so today. however once I hit the highway today, i got the "service" warning and the Tire Pressure light came on. thinking maybe I picked up a nail and was losing air or something, I pulled over and checked all the tires, got back in the truck and looked at the pressure readings, my right rear tire wasnt listed. I shut the truck off to try to reset it, but it didn't work. Shortly there after the other three tires lost their pressure readings. just to clarify, the rocking side to side happened after I lost the Pressure sensor system, no clue if or why that would affect anything, but I highly doubt it should.
now for a question, I was talking to a guy with a new silverado today, hes had it for 800 miles now, and has had to replace the battery 4 times, also his radio will not turn off even after he turns the truck off, and leaves. he says that even 15 mins after leaving the truck, he can go back out and the radio will still be playing. I have found some posts from years ago indicating that it is either a relay in the door, or a switch sticking somewhere else in the truck. has anyone seen this in their new ones or heard of it being a big issue with other new trucks? I havn't so just thought I'd check, ohh and his dealer said that they think the radio is bad, but GM didnt authorize a replacement so they wouldn't spend $700 of their own money to try it.
You have to register the TPMS sensors with the truck after you switch wheels. Each sensor has a unique number that is registered by the computer and then that number is assigned a location, front right, front left and so on. Switching corner locations but keeping the same sensors the pressure readings will still show but be in the wrong location, the computer doesn't know you moved the fronts to the rear or however they were switched. Switching your rim set altogether to a set that has a second set of sensors installed requires that the new set of sensors be registered into the computer and then assigned their location. I have two sets of wheels and tires as well and it usually takes 30-45 minutes before the computer realizes there is no sensor data and the values disappear from the display. I'm not sure if the computer can have more than four unique sensors registered to it or not. Apparently moving the wheels and tires during a tire rotation and telling the computer where the wheel is located can be done with a 70 dollar tool. But telling the computer that there are different sensors than before and registering them takes a much more expensive tool. A local shop here in town said the one they have is $1700. They do the sensor registration for free.
jesus, thats nice of them to do the registration for free, and good to know about it taking a while to register, I had them wheels swapped at the shop my family has been using for over a decade and just assumed they registered them with the truck. I have a bad knee so I didnt feel like changing them myself. thats bullshit to have to pay for shit like that, it should be like a bluetooth thing that automatically knows... anyway they can make a quick buck though i guess
mine is fixed!!!
hopefully it doesn't come back.
new rear axle assembly and new tires seemed to do the trick. looks like mine was a combination of f couple of issues.
congrats man
Got mine if freeway w the new in spec SRAs and it is fine intill 77mph + before it was 60+ and intermittant
well thats better than nothing right?
You can borrow my tpms tool, here is how you do it.
Thanks Bill, let me know when you have some time to go on that test drive with the 18's on, I'd like to get your opinion on how it affected the truck, it'll be interesting to see if you think it affected it the same way as I do. I'll be putting the 22's back on after so I think I'll take you up on the TPMS relearn tool for that.
Just confirmed vibration with another dealership.
I have been reluctant about pushing my regular service manager as he is my best friend and do not want to ruin the relationship over a truck.
I went to a dealership about 25 miles away but in the town I work.
Told him I have a 2014 Silverado with a vibration and has he heard about it.
Yep, they have half about a dozen complaints at their facility mostly highway vibrations. They helped one guy out by changing driveline angles, in his words the truck owner could live with it although the vibration was still there.
He confirmed that it is a driveline vibration and GM is aware but no fix yet.
How about tonight around 6:30 PM ?
this truck is getting weirder and weirder by the day. I just got back to my house, and when I put the truck in Park, the horn went off 2x, no clue why. the vibration feels worse at slow speeds today than it did yesterday. I havn't hit the highway yet today, so that will be determined in a short while.
Ok so the dealer has had my truck for 1 week now. I went to pickup the truck the first time last Wednesday and was told vibration was fixed road forced the tires and replaced 1, before I even got off the lot I noticed a scratch on the steering wheel bezel and a door chip on the driver's side. I left the truck for them to fix these issues, I just left the dealership where they did what looks to be a really good touch up on the door and replaced the steering wheel, I drove the truck and it still has a vibration it's better but still there at 70-80 they also managed to put the steering wheel on misaligned and scratched the chrome on the airbag this time.The other issue I am fighting is the truck seems to pull to the left when in the left lane and to the right when in the right lane, they say it's the nature of the truck even though the loaner does not do it.
I am sort of at a loss at this point as so far I have 12 plus hours just in drive time away from my business and still don't have my truck. I was told that it would be 3-5 days before they could get the airbag. I was also told in order to replace the airbag that they would have to punch holes in both sides of the steering wheel to which I said NO it's a new truck so make it right. I really don't have a very good feeling about this
