LED 921 Reverse & Cargo Bulbs
  • Replies 299
Well i seen this topic i am rocking dyoide dynamics $100 option led bulbs (before the bashing i had an 11 ram 1500 that had them (bulbs were close to new) and had the same part number. I hate them!! Vs my ram
583DC600-096B-4B83-AF7B-A20516E15DAF_zps
2F37BD9D-E266-4726-B88C-FFA2BFDC8C64_zps
Ram 1500
FDF3A1F1-836E-48B7-94C7-BC5CA9B07ABC_zps
1675EBFA-F2EA-4C21-813B-E73F196F025B_zps
I installed VLEDS in plate, reverse, third brake (to include strobe flasher). Very pleased. Couldn't see $60 for what little use cargo lights will get though.
Link?
Sent from my HTC6545LVW using Tapatalk
i added the cargo lights on my ram and it was a little to bright (produced enough light to light up the edges of my lane a few feet behind my truck)
I did my own truck in reverse lights and cargo lights. Wow! Am I ever impressed! I ordered 6000K bulbs off eBay, got 4 for $25 shipped, and with the led lights that are in my tow mirrors on as well, you can't even look at the rear of my truck, it's brighter than the front! Now my license plate light bulbs have to go... they look like a horrible yellow next to these new 6000k whites!
Ram 1500
As a word of caution the lens cap "projector style" bulb in the picture above retain heat under the lens causing these chip LED's to burn out first. If you have an adjustable timing feature for entry/exit lights I suggest you set it to the shortest time possible. I burnt out 2 sets of the lights above before I changed to the VLED 921 without the cover.
  • 1 month later...
I purchased these and do not fit the reverse light. They do fit the bed light. Anyone have any ideas?
I am having this exact issue today with the 1279LPB2 Bulbs, they do not fit.
What did you end up installing?
  • 1 month later...
Just to let yall know, The Philips 921 LED bulb does actually fit into the reverse light socket. Just have to give it an extra push but it does go in. I just installed mine with no problems. Looks great too.
  • 3 months later...
What happens when you pull it back out? Will the bulb come out of its socket and fall off in the housing?
