2014 Sierra/Silverado Bulb Sizes
Looking to replace my license plate lights with these:
http://www.amazon.com/JDM-ASTAR-Extremely-Bright-Brightest/dp/B00JIEX722/ref=sr_1_1?m=A126Q4T86JLNL&s=automotive&ie=UTF8&qid=1437014014&sr=1-1&refinements=p_4%3AJDM+ASTAR%2Cp_6%3AA126Q4T86JLNL
Anyone have experience with this seller or this product? I'm only concerned with it flashing or throwing an error code.
Thanks
Josh
Vled is where you go for a good quality light 51f1703a252b0c39128c34346eeb4032.jpg
Sent from my SM-G900W8 using Tapatalk
Excellent, thanks. Do you think these would work well? No error codes, no fitment issues, and bright enough?
http://www.vleds.com/6k-white-high-power-license-plate-map-parking-led-bulbs-194-168-158-1-pair.html
Thanks
Josh
Thanks
Josh
Iv got a pair for myself on the way and see and many others are using then can also us this to help you when finding lights 94bcc17c7cc3223956303beb58bf009e.jpg8c8f280d1463f49e5ffeca5d594956be.jpg
I got 7443 amber and red for the Denali (front/rear), error codes right away. only solution I know of is to add the load resistors
which I will NOT splice into the wiring harness. Maybe there will be a direct swap with 2016 Sierra, which suppose
to have both LED rear and headlights...
Thanks
Josh
I have those on mine. They were actually better than the 194 VLEDS I bought.
Thanks
Josh
Those will not work in the license plate lights, you want bulbs that have diodes all the way around on the sides. Below are the VLEDs you want for the license plate:
5K
http://www.vleds.com/shop-bulb-numbers/194-168-158-led/6-5k.html
6K
http://www.vleds.com/shop-bulb-numbers/194-168-158-led/6-6k.html
Or you can get the Astars on the other page. I have both bulbs-one set in my truck and the other in the wife's Honda. The Astar license plate bulbs were just as good if not better for half the price.
5K
6K
Thanks for the input. Are the Astars too bright? As in, do they throw weird shadows on the back of the truck because they're too bright for that spot? Also, did you experience any error codes when you put them in?
Thanks again
Josh
These work great. I bought my reverse, license, and cargo lights from this seller. Arrived within 2-3 days. Philips Extreme are great bulbs, throw ZERO errors
http://ebay.com/itm/PHILIPS-LED-VISION-6000K-194-12256-TWO-BULB-PARKING-SIDE-MARKER-LICENSE-PLATE-/131520989437?txnId=1114476023003
Link is dead. Interested in seller.
Hi guys, new to sight. Hoping you can help me out. I know nothing about mechanics, so in need of advice.
I have 2014 Sierra SLT, with the LED accent lights and Halogen protectors (I think). I really don't like the yellow/Amber tint of the headlights.
I understand the stock lights are size 9012LL. From my half ass research, it seems like that has more light output than the 9006. But it seems like a lot of people replace their stock lights with sylvania ultras or ZXEs.
If I switch to one of these bulbs, I will get the "white lights" i want but will they be lower powered lights or less light output?
And am I correct in thinking I can plug a 9006 bulb into my 9012 socket without any mods? Once you have to cut or trim anything, your already far beyond my skill set.
And any other lights you would recommend for me. Again just want white light without tint and no modifications.
Thank you
was changing out my cargo lamp (finally) upon removing the screws .. i dropped one of them ....
the odds of it falling smack in the middle between cab and bed have to small right ... and odds that it lands in that middle area that connects the cab and bed have to be even smaller ..
welp im out of a screw so my cargo lamp is snapped in and screwed in with one screw. Other than that the lights look good. My truck is now 80% (i would say) LED lighting. Just need high beams and fogs
