Gear ratio
If you cannot find the code for some reason, you can jack up the truck by the rear differential until both rear wheels are off the ground and support the axle with jack stands. Then put the truck in neutral, climb under the truck and turn the drive shaft by hand until you see a complete 360 degree revolution of one wheel. The number of turns of the drive shaft it takes to spin a wheel one complete revolution is your gear ratio.
Edited by pm26
Concerning the axle gear ratio on HD trucks, why is it that the optional 4.10 ratio is so rare on dealer's lots? Tow rating is drastically reduced with the standard 3.73 ratio and it seems odd that even most dually pickups with the gas engine are ordered with the 3.73 ratio. Gas mileage should not be of primary consideration when buying a heavy duty truck. And I believe that the 4.10 ratio will actually give you better mileage in city stop and go traffic. There will be some penalty at highway speeds, but nothing drastic. But anyway, I would definitely go for the 4.10 ratio because tow rating is about 3,000 lbs higher, which is significant. Also, with the 4.10 ration you get about 10% more torque at the rear wheels in all gears. This helps move heavy loads from a standing start.
In order to get 4:10, I had to factory order my current and prior HD. It is very rare to find 4:10 on any dealer lot. I don't get it either. It is a $150 factory option. 4:10 is a must with the 6.0 for hauling anything over 10,000 lbs IMO.
Yeah, thanks pm26. I knew that method, I was looking how to get around doing all that, its about 110-115 every day here, so the less I have to do outside, the better. :P As well, I was very happy for the above reasons to find out I had the 4.10 gears.
I am also curious about the WHY ? In the rural areas of the country, the 4.10 would be a great selling point. It must have something to do with GM meeting the government mandated MPG for their fleet....
I dare suggest that in areas such as Tennessee where we have rolling hills that 4.10's would probably yield better gas mileage. My 3.42 truck is constantly downshifting, even on interstate.
