Do the G80 axles have the same axel shafts as others?
Hello all
I have 95 G20 van that I ordered from the dealer and that
from the order I had a Locking Differential put in.
In looking over the special order paperwork I got from the
dealer, it lists G80 for the RPO code for the Axle.
Had 3.42 ratio with code GU6 and with the L05 350 engine if
that matters.
At this point I now have to replace the axle shafts as they
wore down pretty bad at the outer bearing and want to pick up a set but am not
sure if the ones in this rear end are the same as what might have been a
standard, which is what I guess is in most autoparts stores.
For the GM axle shaft part number for what I guess is the
standard as its the only 5 bolt one I could find for this year, it is: 26013313
In looking around for just even a 1995 G20, the most similar
info and what seems to be corresponding with that number is its a: 8.5 in. x 33
5/16 in. Overall Length; 5 Lugs; 30 Spline ....and if this is right, I can just
get a set from the autoparts store.
So hoping someone might know more about this then me an any
help would be appreciated
Thanks
    247.7k
    2.6m
    Jason Coe
    Jason Coe
  • Who's Online   1 Member, 0 Anonymous, 677 Guests (See full list)
