Ready Lift SST 2500HD lift 2011-2013 4"F/2"R
since it has a diff drop and new control arms it should work. Iv always been told not to go over 2inches or CV angles will be bad if you dont drop the diff.. I havent seen much on that kit before. its says to get new shocks, but shock extenders will do fine when you lift the front of the 2500s. you dont have to crank the keys up that far if you dont want the full 3.5.
I called them the diff drop is 1 1/2" about as far as you can go without cutting stuff. I just don't want to pay for the Shocks they sell big $$ 419 a pair. The 2011HD was a bit higher to start with. The tech guy said expect 3.75 front and 2" rear with tow package kit. I would love to do a big lift 6" with 35" tires. But I tow with it and plow with it. Plus I want to be able to use my stock rims in the snow. I'd like to find someone who has actually used this kit.
sorry iv never owned one, but like i said you dont have to replace the shocks, extenders will do just fine. if you plan on plowing and using the truck to tow then i wouldnt go any higher than 3 inches. as i said above you dont have to get the full 3 inches in the front, just dont crank the keys as high. truck will still be functional with that kit. im sure you could search other forums for people/reviews on it.
