yukon25008.1 Posted January 24, 2013 Author Share Posted January 24, 2013 Its gonna go in the 04 silverado I just picked up with the 240,000 mile 8.1 Why? Link to comment Share on other sites More sharing options...
6Sixathome Posted January 24, 2013 Share Posted January 24, 2013 Just curious, seems like a fun project. Link to comment Share on other sites More sharing options...
yukon25008.1 Posted January 24, 2013 Author Share Posted January 24, 2013 Yea.. Like I said the guy has one in an 86 or 87 stlye truck And he said it was easier then he thought, So putting it into a truck that came with that motor shouldnt be so tough especially with the allison already there. Im pretty sure the one I won comes with the ecm/pcm and tcm.. Even the rear because its an 8.1 truck has the 11.5 ring gear. Link to comment Share on other sites More sharing options...
sillywillie07 Posted January 25, 2013 Share Posted January 25, 2013 C/k out duramaxfourm.com. Lots of good info. transdyn fluid is what I would put in the trans. Link to comment Share on other sites More sharing options...
SarahsGMC Posted January 25, 2013 Share Posted January 25, 2013 Lol this title made me think you got the whole truck for that much Sent from your truck via Tapatalk Link to comment Share on other sites More sharing options...
yukon25008.1 Posted January 25, 2013 Author Share Posted January 25, 2013 C/k out duramaxfourm.com. Lots of good info. transdyn fluid is what I would put in the trans. Thanks, Whats the deal with the transdyn stuff? Is it full synthetic? Link to comment Share on other sites More sharing options...
'01LS1 Posted January 25, 2013 Share Posted January 25, 2013 The Transynd is what you want. Had a '07 Allison 6 spd & believed a oil salesman that their stuff was as good. It wasn't & the trans shifted weird until I flushed it out & replaced with Transynd again. Temps stayed cooler as well. Fwiw, another guy I know had a 07 Dodge 3500 Cummins & used Amsoil exclusively in everything. The only thing it did not work in was the trans in that truck & went back with the factory recommended stuff. My point being that I always thought approved this or that was probably a buy in sort of deal. With the trans fluid it was not the case. Link to comment Share on other sites More sharing options...
yukon25008.1 Posted January 25, 2013 Author Share Posted January 25, 2013 Yea ill check it out. Is that thru allison? Link to comment Share on other sites More sharing options...
truckofwinandawesome Posted January 25, 2013 Share Posted January 25, 2013 The Transynd is what you want. Had a '07 Allison 6 spd & believed a oil salesman that their stuff was as good. It wasn't & the trans shifted weird until I flushed it out & replaced with Transynd again. Temps stayed cooler as well. Fwiw, another guy I know had a 07 Dodge 3500 Cummins & used Amsoil exclusively in everything. The only thing it did not work in was the trans in that truck & went back with the factory recommended stuff. My point being that I always thought approved this or that was probably a buy in sort of deal. With the trans fluid it was not the case. I've said this once, I've said it a thousand Times, and I'll Say it a Thousand more: Use ATF+4 AND ONLY ATF+4 in a Chrysler Transmission; Anything else will cause the Transmission to not work right (or in Extreme Cases, completely destroy the Clutches and Solenoid Pack!) Link to comment Share on other sites More sharing options...
'01LS1 Posted February 4, 2013 Share Posted February 4, 2013 Yea ill check it out. Is that thru allison? There was a local commercial truck dealer who I got both the Castrol Transynd & the red spin on filters from. Filters were like $8 & right at $20 per gal. on the fluid. Pretty sure I checked with GM & they were higher, but do not remember the differences now. I owned that truck from 2007-2011, so prices may have changed as well. Link to comment Share on other sites More sharing options...
yukon25008.1 Posted February 5, 2013 Author Share Posted February 5, 2013 Yea ill try the right fluid.. I know dex-6 is a great fluid but if the Allison does better with the transyd that's what im gonna give it! Link to comment Share on other sites More sharing options...
