What did you do with your truck/shop today
SarahsGMC
Found a match for our patio rock and hour away from the house.
Loaded 800 # of it plus 250# of crew. Truck rode well. 18mpg hwy. no blown shocks, this better than my last experiance hauling.
Will get some more rock next time I'm down in Santa Rosa.
Click on pic to see it right side up.
Edited by Gofas
Had to make one more lumber yard run for 5 more sheets of plywood a couple days back - porch roof deck was worse than I thought once I stripped the old roof off.
Making progress though. Got all the edge metal on & capped. All seams sealed, and 2 of them capped.
Day 5 starts now. Just have to reinstall siding, and put a cap sheet on one last seam, them I'm DONE. Finally! Been putting this off for 13 years, lol.
Hopefully it didn't cost much. Should be a pretty easy fix.
My parts guy (Rich) came through again :)
I might owe him a lunch when I am in Pittsburgh in July.
I was going to top off the front diff but last night decided to just go ahead and change the fluid. Took the skid plate off and scrapped 20lbs of mud/sand off of it and then drained the diff. Had some shavings on the plug, I attribute that to the previous owner's neglect of maintenance. I changed the fluid when I first got it, it was not healthy looking fluid then so now hopefully the diff is a little happier getting a flush and fill again. Also started taking measurements to get a splash guard fabricated. It'll be nice to have a splash guard to help keep the underside a little cleaner.
Shouldn't be too bad, seeing you're from GA. Up here, they usually either rot completely off, or the bolt is so rusted you strip the Torx splines right out of them.
My '94 S10 plow truck's tailgate is held on only buy the upper locking mechanism ... :lol: Cutting torch is the only way what's left of them will come out.
I wish I had a parts guy or even better, someone to help out with wrenching!
The first time I read this, my brain shorted and I thought it had two words swapped, and woah does it make a difference
I wish I had a guy parts or even better, someone to help out with wrenching!
Edited by SnakeEyes
