What did you do with your truck/shop today
SarahsGMC
Looks like your rebuilder sux.
It's funny cause he's well known all over the inter webs and I've only seen one other person on ls1tech.com have an issue with him. I'm sure oversized tires weren't helping but no reason for it to fail so soon
Sent while in 'Murica...
Did you do like every other guy that gets a new trans and beat the piss out of it first thing?
Nope. Didn't take it above 4k rpm and no hard launches until the first drain and refill at 2k miles. It's just my luck with transmissions I suppose
Woke up early and checked everything over on my truck and topped off the tank before going to work. Supposed to be 60MPH winds and the freeway is going to probably flood before I get off work. Expecting 15" of rain and the freeway borders the ocean. Probably going to end up taking a dirt back road home tonight. So my 30 mile commute home will probably turn into a 60 mile commute home.
Looks like I'll be buying a Mag-Hytec diff cover soon so I can change out the gear oil. Since I have the oil coming out of both front and rear diffs, I'm wondering if I should pull the sucker out and put in some 3.43 gears... things to ponder.
I guess your luck is way worse than mine. Personally I'm thinking the rear end will go out first.
My factory one was with the truck till 308k and since then I've had issues. The one rear end was rebuilt with cheap parts and the last one had a rotted housing
Do you have like 3.08 gears now? I made sure to look for the trucks with 3.42's. Luckily, all the high country's come standard with them
