Brian66D Posted March 19, 2012 Share Posted March 19, 2012 So I installed my fatbobs leveling kit this weekend (same as the RC kit)... in probably a record time haha It took me and a friend all of maybe 15 minutes to do both sides(minus the alignment)...we did have a lift and any tool imaginable at our disposal (including an alignment rack) also which helped... now this picture doesn't show very much because of the angle...but I feel like after looking at hundreds of pictures of GMT900s with 2" front leveling kits I feel like mine isn't as high as everyone else... I do still have a little bit of rake... Now my question is....where can I buy this .5" spacer people are talking about to get a "2.5"" leveling kit in the front? I would like to do this because I want to replace my rear block with one from a GMT800 to give myself .75" higher in the rear. my truck only has 6k miles on it...so I don't want to get too crazy, but what are some suggestions for a bigger lift that can be reverted back to factory if necessary? I know with the 6" kits you have to drill the control arms and yada yada yada... I do want to go bigger without doing anything to the body. At most I would do a 1.5" body lift but I would really like to stay away from that. Does anybody have a 3" suspension lift out there that can be used with the front leveling kit and doesn't have to be permanent? Link to comment Share on other sites More sharing options...
cparks555 Posted March 19, 2012 Share Posted March 19, 2012 Fat Bobs, I ordered one for my truck last week. I couldn't find it on their website, just call them. Link to comment Share on other sites More sharing options...
scz71864 Posted March 19, 2012 Share Posted March 19, 2012 i have not heard of a .5 kit in the front Link to comment Share on other sites More sharing options...
Brian66D Posted March 19, 2012 Author Share Posted March 19, 2012 i have not heard of a .5 kit in the front a lot of people have the "2.5" " front leveling kit.... Fat Bobs, I ordered one for my truck last week. I couldn't find it on their website, just call them. you ordered the .5" spacer from them? Link to comment Share on other sites More sharing options...
cparks555 Posted March 19, 2012 Share Posted March 19, 2012 i have not heard of a .5 kit in the front a lot of people have the "2.5" " front leveling kit.... Fat Bobs, I ordered one for my truck last week. I couldn't find it on their website, just call them. you ordered the .5" spacer from them? You have to call them and ask for it, not on the website for some reason. Its actually a 1" level, but in two pieces. You can use one piece which is .5 or both together for 1. Link to comment Share on other sites More sharing options...
Brian66D Posted March 19, 2012 Author Share Posted March 19, 2012 does it go on top of the strut? or is it an add on to the below the strut levling kit that is already there? Link to comment Share on other sites More sharing options...
doodeediddledodindee Posted March 19, 2012 Share Posted March 19, 2012 The real question here is if you even have a 2in lvl, you say you did it so quick that makes me think you might not have had to drop the upper ball joint, if you didn't have to drop the upper ball joint to get the spacer in then it isn't big enough to give you a 2in lift. Link to comment Share on other sites More sharing options...
Brian66D Posted March 19, 2012 Author Share Posted March 19, 2012 The real question here is if you even have a 2in lvl, you say you did it so quick that makes me think you might not have had to drop the upper ball joint, if you didn't have to drop the upper ball joint to get the spacer in then it isn't big enough to give you a 2in lift. lol I can assure you I have a 2" leveling kit installed. I used to be an assistant service manager/service advisor and I had a certified master tech help me install it. We did the same install process as seen in this youtube video...very doable with 2 people in fifteen minutes on a lift. It literally took no time at all because once the truck was on the lift everything went with ease. I loosened the nut on the control arm and dropped it down, loosened the sway bar, and he popped in the spacer. Then he tightened everything back up as I moved to the other side. It couldn't have been more than 15 minutes... Then I left to go golfing and he did the alignment & put in my body colored door handles so I'm not sure how long the rest of the process took. I got back from the course and my truck was sitting there done. Link to comment Share on other sites More sharing options...
SouthCo Posted March 20, 2012 Share Posted March 20, 2012 Looks nice. Link to comment Share on other sites More sharing options...
scz71864 Posted March 20, 2012 Share Posted March 20, 2012 this .5 spacer goes on top of the spring correct? Link to comment Share on other sites More sharing options...
cparks555 Posted March 20, 2012 Share Posted March 20, 2012 Alright guys, Fat Bobs sells a .5" level that is the lower strut style. $31 shipped, or the 1.5" which is 1" lower strut combined with .5" upper for $110. Link to comment Share on other sites More sharing options...
