Christiank22 Posted March 3, 2012 Share Posted March 3, 2012 I got a 6in BDS suspension lift on my sierra and when I first got the lift in it sit level but it seems to sag to where the front sits higher than the rear, maybe I'm the only one who notices it cuz its my truck but it bothers me. What do you guys think I should do? Also I am installing a 1.25in body lift to stop the tires from rubbing do you think that should level it out? Link to comment Share on other sites More sharing options...
BlackZ71Silverado Posted March 4, 2012 Share Posted March 4, 2012 A body lift won't level your truck. Most trucks you see that are lifted sit higher in the front. You can replace your rear block with a taller one, or add a leaf to get the rear of your truck level. Link to comment Share on other sites More sharing options...
Christiank22 Posted March 4, 2012 Author Share Posted March 4, 2012 Oh alright, thanks! I'm not getting the body lift to level it though I'm only getting that to stop the rubbing it has torn the plastic inside my wheel well so something has to be done about that I was just wondering if that would maybe help solve the problem! Link to comment Share on other sites More sharing options...
BlackZ71Silverado Posted March 4, 2012 Share Posted March 4, 2012 A body lift will definately help your tire rub issue for sure. Link to comment Share on other sites More sharing options...
Chiefmorton Posted March 4, 2012 Share Posted March 4, 2012 I would get a little taller block for the rear, not much money and easy install. Link to comment Share on other sites More sharing options...
cparks555 Posted March 5, 2012 Share Posted March 5, 2012 I have the exact opposite going on, front end has settled. Chiefmorton makes a good point. Link to comment Share on other sites More sharing options...
ruggedlife Posted March 6, 2012 Share Posted March 6, 2012 bds comes with a 4" block and a add a leaf, i would recommend the new rear springs instead... and i'm guessing your monster's are -12mm offset which is causing most of your rub issues, i went the same route a 1.25 body lift it helped a lot, however when i hit a turn/bump right it will still catch some fender even with significant trimming Link to comment Share on other sites More sharing options...
