Another Leveling Kit Question
I swear somewhere reading on here someone said they installed their leveling kit without actually taking out the UCA, sway bar, and steering linkage but just loosening them and that way no alignment was needed afterwards. Am I just pulling this out of nowhere or is this actually possible?
There's no way you won't need an alignment since the leveling kit pushes the toe out. However you don't have take out any of that stuff. I was able to install mine by loosing two bolts and removing the two on the lower shock mount. Check out this
for a quick install. It was really easy and straight forward. Good luck!
