zach1990 Posted February 16, 2012 Share Posted February 16, 2012 got a 2 inch rc level on my truck and got a big problem. my shocks no longer fit my truck and the best the local store can do is order me some rancho 4 inch lift shocks. now my question is will these work or is it gonna cause problems? i have the torsion keys cranked to about 2.5 inches if that helps any Link to comment Share on other sites More sharing options...
Silverado4x4 Posted February 16, 2012 Share Posted February 16, 2012 Whos is telling you that the shocks dont fit? If its the shop then there trying to sell you shocks and rip you off. A leveling kit just brings your suspension down but doesnt change where the suspension hits the lower bump stop so longer shocks are not needed. So bottom line is that your suspension travel has not changed with a leveling kit just the downward travel is closer to the bottom bump stop. Your suspension will bottom out before the shocks will up or down. The only time you need longer shocks is when you go to a full suspension lift. Link to comment Share on other sites More sharing options...
zach1990 Posted February 16, 2012 Author Share Posted February 16, 2012 well im doing the install myself and the monroe shocks i have are stretched all the way out and as much as im trying i can not for the love of me the shocks to go up far enough to bolt on ( if that makes sense). Link to comment Share on other sites More sharing options...
zach1990 Posted February 16, 2012 Author Share Posted February 16, 2012 and before it gets asked i took the shocks off in the first place to put that little metal spacer on top of them that rc sends with the torsion keys Link to comment Share on other sites More sharing options...
LURCH HD Posted February 17, 2012 Share Posted February 17, 2012 If you put after market keys on your truck you will need shock extensions or longer shocks. I done my 02 which is the same as 99 to 06. I do have a set of new Fat Bobs Garage shock extension's that I would make you a killer deal on. If you are interested please let me know. Thanks LURCH!!!!!! Link to comment Share on other sites More sharing options...
zach1990 Posted February 18, 2012 Author Share Posted February 18, 2012 yeah i tried to raise it a little higher in the front to give it some lean since i hardly ever tow but seeing as it looks worse than i thought it would and like you said the joints are so bad they pop and creak going down the road. fixing to lower the front in a few minutes and make it perfectly level. ill try to post pics up later Link to comment Share on other sites More sharing options...
Silverado4x4 Posted February 18, 2012 Share Posted February 18, 2012 If there popping and creaking now you may have done the damage. Link to comment Share on other sites More sharing options...
