getting more caster?
I recently cranked my torsion bars up on my truck to level it. I went to get it aligned the other day and they said they got the camber and toe adjusted right, but ran out of adjustment on the camber. He said he got it better than it was but he had to put it at 0 degrees. My question is how can I get more adjustment with it? Maybe I should start with where do you adjust it at?
I cranked them about 2 inches, and dont really want to crank them back down since my tires rub occasionally when turned all the way. And the only reason I want to fix it is because it wanders down the road now and has no pull to center now. Before the truck set 3 inches lower in the front so its not even level yet and he said he didnt have enough caster adjustment?
