Max tire size ? 2" leveling 3" body
If you want to run a 33", you can get into a negative offset (tires stick out more) if you like that look. For the most part, you could clear a 33" tire without the BL, but the offset would have to be more closely selected. With a 35", you should stick as close to stock as possible.
Any idea what wheels you are planning on runnig? That info would greatly influence your tire size options without trimming.
