help with awd denali
i am getting ready to buy 08 AWD sierra denali and it seats way to low
does anyone know if leveling this truck with make it vibrate and ride like crap or should i be ok with just going with a leveling kit
i have also heard you cant left them and that would suck for the future unless a company came up with a kit
thanks aj
if a leveling kit would work please let me know which kit to get please
Well, some will and some won't vibrate with a leveling kit. If you keep it to 2" similar to the 2" RC leveling kit, I think you'll be fine. If you want more, I'd look at a body lift. And you can lift them. I've seen many :thumbs:
you can lift them youll just need a new front drive shaft and a lift kit that keeps your angles fairly flat, like fabtech 6" or bds 4", of course a 3 inch body lift will work, and sometimes you can level them in the front sometimes you cant, if it ends up vibrating i would lower the back down to match the front and then do a three inch body lift, getting you some lift but also giving you a level stance.
I'm not a big fan of the way a lifted GMT900 SD looks. In fact it's fugly. A lifted GMT800 SD looks much better. An SD is the BLING version of the Sierra. Just don't get the point. It's your rig and you do what you want. You might get some more pinpointed responses on the SD lifts from denalitrucks.com. Just sayin.,,
