Rc Level, 3" Blocks, And 295/70r17
I installed the rc level kit, which was extremely easy. The rear blocks(bought from rough country) were harder only cause the rear rolled forward and kicked to the passenger side so i had to fight it back over. Other than that i was done the whole thing in 2 hrs including set-up and clean up. I installed 295/70r17 Nitto Terra Grapplers on the stock rims, they do scrub a little bit, but only on the driver side when i reverse and cut the wheel hard, but i have to hit the gas to dip the nose down so it rubs. Yes my truck is dirty but its a truck. I just wanna say thanks to all the guys on here that helped me with my choices to get my truck just how i wanted it.
I have heard that when you install taller blocks in the rear, it is recommended to upgrade the rear shocks at least to something like a rancho 5000 or even the more expensive 9000xl series.
Now I don't have any aftermarket suspension stuff myself so I can only speak from what I have read on various boards.
But if you just think of the basics of suspension geometry and how the stock suspension was designed, anytime you deviate from stock, you would expect the stock shocks to not be able to keep up as well.
I have found that it rides the same until i hit a large bump i.e. train tracks and then i hear a clunk. That is my shocks extending all the way out. If you look at the pic of my rear block you will see that the shock was extended by almost 2". They do sell shock extensions but there $65 and i can buy a pair of new shocks for $100- 120, so i'll let the old shocks wear out first. When i upgrade, it just has to be a longer shock nothing fancier than that.
When I did mine, I opted for the Ready Lift extension brackets. They work out great but do put your shocks at a little different angle. Haven't noticed if it makes a difference from stock ride angle or not.
