Center Cap Removal
Hey everyone. I am having trouble taking the center cap off of my stock wheels on my 09 Canyon SLE/WT. It is a cap just over the lug bolts, no plastic lug nuts to be unscrewed. Ive tried prying but that dosent do anything but chip the plastic cover. Any help is appreicated. Thanks.
Did you try the manual? Or maybe a sticker somewhere near the jack that shows how?
  • 1 year later...
Hi,
Each center cap has two small holes in it.Automotion products sells a thick wire device designed to fit into the holes and you then give a little jerk outward to remove the cap.you could also make your own cap puller from a wire clothes hanger by copying the commrecial version.Finally with the wheel removed,you can just push the cap out from behind.
