Buckets And Light
Quick couple of questions folks,
On my 1994 SL Ext cab does anyone know if I can fit a set of buckets and console in her? Even from a 95-6?
Also it seems the light is not working on the 4x4 floor shifter when I shift to 4low....the front axle does not light up but it does go into 4x4. Is there a bulb burned?
Thanks so much...just bought her and trying to fix the small things first
You can bolt in the bucket seats from a 92-94 but the 95-98 will NOT fit unless you change the door panels as well (trust me, I tried :rolleyes: )
Not sure, but it sounds like it.
